What is the number in the /367/ part of the url? Is that something myzuka generates? If it is, then you'd have no way to know it from MB and couldn't generate the tag. If it's not needed, then it possible. If you need that, I don't see how you'd make that link unless you somehow scraped the myzuka site for all the values and then imported those values to MB in a custom tag (complicated).
