Author Topic: Streaming music from MusicBee to my friends  (Read 1751 times)
fveitsi
I just want to stream music from MusicBee to couple of my friends. Is there any plug-in for this purpose? Thanks!
-JP
You might want to look into Subsonic (subsonic.org). And while there is a plugin for MB, I have found that it doesn't work correctly, and it's no longer supported.
So to use Subsonic without the plugin, I point it to my music files and I export my playlists from MB. Subsonic does the rest.
