Hello.
I'm going through my songs, and some of them need to be edited to delete extra sounds or change the fade-outs, etc. So, I'd like to be able to put a checkbox or "OK/Fix" dropdown in a column so that I can mark them as I listen to them.
So, if they have a checkmark, they are good, but if they don't, I either need to listen and evaluate them, or fix them.
And if I start this, and if I come back to it later, I'll not have to repeat what I've already checked.
Is there a way to add a note or checkmark for each song so I can accomplish this?
Thanks for your help as I use this more and more.
Regards,
leaning
