Author Topic: Double-clicking a file to play it doesn't always work properly  (Read 3479 times)
Sigma
I'm using the latest version of MusicBee 3.0.
The expected behaviour is that when I double-click a file that's associated with MusicBee, MusicBee will open and that file will start playing.
What sometimes happens is, I double-click a file, MusicBee opens, but it begins to play whatever is the last track I was playing the last time I closed MusicBee.
This doesn't always happen and I can't pinpoint the cause of it.
the first time i tried this i had the exact same behavior but now i cant reproduce this, nor can i see how it would happen.
So let me know if you are happy to run a debug version.
Also could you send me a link to your settings file (help/ support/ view settings)
Last Edit: May 29, 2016, 04:00:13 PM by Steven
Sigma
Yeah, it's an odd one for sure.
Here's my settings file: -
http://www5.zippyshare.com/v/yCcWBwpq/file.html
And I'm fine with running a debug version. Just let me know what I need to do. :)
nothing has been changed. If you send your settings file i will have a quick look
