Author Topic: Search Issues  (Read 2533 times)
cartman005
There are a couple of issues that I have noticed with the search box in v3.0. I will try and explain them.
1. Press CTRL+F, enter a search string and change focus back to the library. Press CTRL+F again. The cursor will begin typing at the end of the existing string. The old behavior was to highlight the existing search string so that it could quickly be overwritten.
2. Press CTRL+F, enter a search string (Eminem) and change focus back to the library. Press CTRL+F again and enter a different search string (Lil Wayne). Go to another tab and delete a file or move a file. Return back to the original tab and the search box will now contain the original search (Eminem) instead of the most recent one.
for 1, i have changed the behavior so its consistent with v2.5. Thats done for the next patch version
for 2, following those same steps i cant reproduce (I can see it happening in your gif file). As it doesnt seem a very common scenario or serious issue i will leave it unsolved
