Author Topic: Get tags from other files in the same album to write in tag  (Read 1533 times)
tompeto
To be able to get values from the other file tags of the same album of a song, such as rating and duration and also track count and total duration, so it would be possible to use those values to create a formula for a custom album rating (in a custom or virtual tag).
i think its very hard to implement in realtime. also you can use 'library reports' command of 'additional tagging and reporting tools' plugin. this command is a bit difficult to understand, but there is a couple of predefined presets.
