I've just performed a test here, to be sure.
The transfer must be done in several steps.
First, let me just rephrase what you've tried so far (at least, what I've understood, so please correct what is not accurate).
Situation 1
* 'Catalog number' was stored in MB database only.
Situation 2
* You created (via Preferences -> Tags (1) -> [Define New Tags...]) a new custom tag named 'Catalog number'
* In Preferences -> Tags (1) -> custom tags, for 'Catalog number, you switched from 'Save to MusicBee database only' to 'Catalog number', and save.
=> MB automatically rescanned your entire collection and wiped 'Catalog number' in its database for all the tracks.
Now, what you must do (tested here with success).
Make sure you start again from Situation 1 (after restoring the correct .MBL).
Make sure that plugin "Additional Tagging & Reporting Tools" is installed.
Steps:
(1) In Preferences -> Tags (1) -> custom tags,
rename 'Catalog number' to 'Catalog number OLD'
(2) In Preferences -> Tags (1) -> [Define New Tags],
define a new custom Tag named 'Catalog number', and [Save].
(3) In Preferences -> Tags (1) -> custom tags, in a free slot,
set:
display name = Catalog number
save to music file as tag = Catalog number
(4) Make tags 'Catalog number OLD' and 'Catalog number' visible in the current view (Album & Tracks, or Tracks)
Then, perform a test with a few tracks:
(5) MusicBee Main menu -> Tools -> Additional Tagging & Reporting Tools -> Copy Tag...
copy tag Catalog number OLD to tag Catalog number,
and [proceed]. (You may have to close the window when done, if it doesn't close automatically.)
(6) With the selected tracks, right-click -> Send to -> File rescan
to refresh the display => now, you must see the same values in Catalog number OLD and Catalog number.
(7) If it's OK, you can do the same for all the tracks.
Then, you can wipe Catalog number OLD.
