Hello, I am new to MusicBee and I seem to have discovered a bug. I am on Windows 11 using Musicbee 3.6.9202 P.
When the columns browser is hidden via panel customization, changing between vertical to horizontal causes the entire Musicbee window to resize bigger!!
This happens in panel configuration, when a hidden columns browser is changed from vertical to horizontal. It also happens when switching between tabs in which one has columns browser as vertical and the other horizontal, but again only if one or both have hidden the Columns Browser via panel customization.
If the columns browser is not hidden in panel customization but is hidden via the configure layout menu the issue doesn't happen.
I don't know if its related but I do have dpi scaling in Windows 11 set to 150%.
