Hi there. I have been searching the internet for hours now trying to find an answer to this question, so I hope someone can help me out here.
I just added MusicBee to my new PC. I use it for podcasts only at this time (subscribing, downloading episodes, sorting episodes into playlists, etc.). I started downloading some episodes but pretty quickly decided that I don't want to download every single one since I subscribe to a lot of podcasts and that can take up a lot of space on my PC. So I started marking episodes I didn't want to listen to as "Listened" and left the episodes I want to listen to in the future unmarked. However, MusicBee doesn't seem to have a way to organize by this metric (which is super frustrating btw).
So I made a custom field called "Listen" where I would mark unlistened episodes as "No" (as in *no* I have not listened to them) and episodes I have listened to / have no desire to listen to will be marked as "Yes" (as in *yes* I have listened / signaling this is something that I don't need to listen to again or ever). However for some reason, MusicBee is not letting me edit this field when I right click the track, click edit, and go to Tags (2) where the custom field is located. The internet seems to think it is because my files are "read-only" however, I was able to edit multiple episodes another way with no issue: by adding the field as a display field. When it is on screen and I click within the column, I am able to edit the field to my hearts content. This could work fine, except marking each podcast episode one by one is not the path I chose to take in life...I'd much rather bulk edit, which I can't do since the field won't let me type anything in it when I right click - edit.
Right click - edit not only doesn't work when I select multiple tracks at once but also doesn't work when I try to edit a track individually. Clearly the track can be edited since I did it for multiple files. And I guess for added context, I have only added one podcast feed so far, so I highly doubt that only some episode files are read only and some aren't. Again, I can edit the field directly if it is a column in my view, but if I want to edit multiple files at once and I right click - edit, the field is grayed out.
Anyone know what I can do to fix this? I'd like to be able to use this feature so I can save space on my computer and make unlistened episodes easily accessible.
Thanks everyone!
