Also would it be possible to have the orange center of the vinyl change in color depending on the colors of the album cover?
Depends, but most probably not. Off the top of my head:
- Is the vinyl background image a solid orange itself?
- If so, I'd then experiment with making that region transparent. Then overlaying the image on top of the BackgroundAlbumCover element.
Edit: but if memory serves well, the above-mentioned element has display priority over all other elements, meaning you cannot overlay anything on top of it.
