Author Topic: Error On Shut Down  (Read 419 times)
nighthawk68
When I exit out of Musicbee with background processes running I get this error every time. I click yes to the pop-up. I was on the latest version but same error after upgrading to 3.6:
MusicBee v3.6.9202.37404D  (Win10.0), 28 Mar 2025 18:43:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
   at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()
   at System.Windows.Forms.Application.ExitInternal()
   at System.Windows.Forms.Application.Exit(CancelEventArgs e)
   at #=zYdI5i8kMzDGj8sVmbUvsI5QqkU2Q.#=zaP7bE58=.#=zi54Znw0=(ApplicationCommand #=zvOpMj8w=, Object #=zBu_gETQ=, IList`1 #=z_v6Nfh8=)
   at #=zWXWPzxFdEEVvDvYDO$H4DEo=.OnClick(EventArgs #=zcSC7hHA=)
This fixes the issue:
https://getmusicbee.com/patches/MusicBee36_Patched.zip
