Author Topic: ...Duplicates caused by a filter that I created  (Read 459 times)
ethan417
Hi
I edited a filter and suddenly I have 2 of everything - just for this specific filter.
What is the best way to clean this up?
Many thanks
Post a screenshot of the filter config.
ethan417
My music is in 2 formats.
FLAC and AAC
I only want the FLAC copies in my library.
I accidently changed the filter to include both FLAC and AAC
So now I have both
I want to delete the AAC
If that's not possible, clear all music in this particular filter and then reload?
Edit the filter to remove the format you don't want.
Or
Delete the filter and create a new one.
ethan417
Hi
Thanks for your help.
Unfortunately, it didn't work.
I deleted the filter.
Closed Musicbee
Reopened
Created new filter
Duplicates for all albums in that Genre
Thoughts?
You were talking format before and now you're taking genre.
If you deleted the filter and created a new one you didn't set up the criteria correctly.
You've been working with this filter since your post in 2020. Has it worked up until you edited it today?
Again - post a screenshot of the filter config.
  • Heal The World
Ethan, as phred has pointed out a few times, please share a screenshot of your filter criteria because that's where the issue lies.
We need to see exactly what your criteria says before advising why you are seeing "duplicates" of formats or genres.
Strength and Honour (2025)
I've asked twice and Mayibongwe has asked once. If you're not going to post a screenshot, then I'm not going to waste my time trying to help you. And neither will anyone else.
  • Heal The World
Apologies - for the delay.
Thanks for the above - I've corrected your image link to point directly to the image source.
You can quote this post of mine in order to see the difference between the link you had and the one I have.
Back on topic:
My music is in 2 formats. FLAC and AAC
I accidently changed the filter to include both FLAC and AAC.
So now I have both. I want to delete the AAC
Oops, I have just realized that you had already attempted embedding the image link but hadn't done it correctly as well (hence why it wasn't showing).
Sorry for assuming you were intentionally ignoring the request to provide the screenshot.
Regarding the above in red, are you saying that you clicked the minus ( - ) button next to the AAC filter and it didn't remove those results?
ethan417
Again, apologies for not getting back to you sooner.
I am in Jerusalem GMT+2 -  so if you're on the East Coast, it's +7 hours
Here is the the original filter after deleting the previous and recreating it.
You can see from the image that the Duplicates are still here
tjinc
Here is the image you attempted to embed - you need to ensure that the link includes the file extension (i.e. .jpg or .png):
We can see from this that there is no issue with your filter.
Next to one of each of the tracks displayed there is an exclamation mark - if you hover you mouse over that it will display a pop-up message, presumably telling you that the file is missing.
My guess is that you have moved these files (or renamed a folder) outside of MusicBee and duplicate entries have been created in the MB database when re-adding or re-scanning.
My suggestion is to rescan all files (Tools > Advanced > Rescan All Files). Give it a minute to complete and it should populate a list of all missing files and will allow you to delete these entries from the library (look through the list to make sure you are happy to do so first).
ethan417
thank you so much for your help.
It worked
FYI: I did change the folder name
