I built a library initially from my 14T peripheral/external drive. E. Made a folder and loaded all of my backing tracks and lrc files into that one folder. Then pointed Musicbee to that E folder. But I'm getting some lag, so I made a new folder on one of my SSD internal drives, D. Opened Musicbee. Made a new library. But cannot
delete the E library.
PROBLEM is . . . When I add new songs to the D folder, then try to update/scan for added files, in Musicbee, I only have the option to scan the E library! There is
ONE checkbox, next to the E location. And no other option or choice. D does not show up as a scan option.
So any new songs, which aren't in the E drive aren't being found.
I cannot figure out how to delete the E library. TIA!
