Author Topic: [FR translation spelling mistake]  (Read 284 times)
u_g_e_e_h
Hello whoever is reading this, I just wanted to point out a spelling mistake in the French translation of the soft.
When choosing research fields like album, title, year etc... Bit Depth (Profondeur de bit) is displayed as Prodondeur de bit.
Could this be fixed?
Thank you for the work for the community.
Technically not a bug as it doesn't cause any issues with the program itself.
Report it on the thread for the translation you're using so the author can see and correct it. It's in the Localization section under Customizations.
