Author Topic: Albums say "No Cover" when the embedded cover is there  (Read 192 times)
darkmaster006
Basically, some covers, for some reason, show "No Cover" when the embedded cover is actually there.
Like this: https://imgbox.com/uBZ2bL5X
And when I press "Analyze files", the  cover appears:
https://imgbox.com/kXf56oVe
Any idea how to fix this and have the covers be all analysed or just have it work? Thank you.
check artwork retrieval settings, then click "rescan artwork", then click "save":
p.s. maybe you will need first to click "save", then re-open retrieval window, and click "rescan artwork". not sure.
darkmaster006
Thank you, this seems to work like a charm so far! Consider this solved :D.
