Author Topic: Error report  (Read 306 times)
Snibborg
MusicBee v3.5.8698.34385D  (Win10.0), 24 Jul 2024 23:14:
System.ArgumentOutOfRangeException: Parameter must be positive and < Width.
Parameter name: x
   at System.Drawing.Bitmap.GetPixel(Int32 x, Int32 y)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=z2rJA_yEmiM8IcOFP5A==.#=zXp5s1ddaSeGsdcAt5c0Ug7o=.#=zvkDQXJ_MqPxGlpZlQw==.#=zPVjvai8TGiYI(Boolean #=zJzEK6zIeUgMi, Boolean #=zCMjlsYnlYOfZvONWRQ==, Boolean #=zjEt1G$dR5cowMWMvRw==)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=z2rJA_yEmiM8IcOFP5A==.#=zXp5s1ddaSeGsdcAt5c0Ug7o=.#=q$5Ut0ZUXsMqZEBGiw1nk8eNM7Q7LZzr22q6v8998IHY=._Lambda$__0()
   at #=zNw1gc6dmr6WcbwzSi_PPhpuKB_Qz.#=zQnBOczs=(MethodInvoker #=zXCP2iIs=)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=z2rJA_yEmiM8IcOFP5A==.#=zXp5s1ddaSeGsdcAt5c0Ug7o=.#=zCoOne$UCj86H(IList`1 #=zDXCBk2c=, TagCode #=zumyIR$Y=)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=z2rJA_yEmiM8IcOFP5A==.#=zCoOne$UCj86H(IList`1 #=zDXCBk2c=, TagCode #=zumyIR$Y=)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=zCoOne$UCj86H(IList`1 #=zDXCBk2c=, TagCode #=zumyIR$Y=, Boolean #=zC3rd__3$$ZZm)
   at #=zNw1gc6dmr6WcbwzSi_PPhpuKB_Qz.#=z$bhcn7NMix_L(IList`1 #=zDXCBk2c=, TagCode #=zumyIR$Y=, Boolean #=zC3rd__3$$ZZm)
   at #=zD3hfp8uekO_N6Yk8tlpS1fLBlQOH.#=qkzhImnuSQLFw$k6wJPQjwx3Gu0VIFZl2hAaCAS0xGR0=._Lambda$__0()
What were you doing when this happened?
Does it happen every time you do what you did?
Did you happen to (try to) load a new skin and this happened?
