Author Topic: Artwork view: Single click to show, double click to open separate panel  (Read 606 times)
fiso64
This is just a simple request to make the option 'show tracks for the selected album or artist' > 'in a separate panel (double click)':
into a separate checkbox that can be toggled independently of the other three. They don't seem to be mutually exclusive, since all the others are activated with a single click. That way, it would be possible (e.g) to show the tracks directly under the selected album with a single click, and to navigate to the separate panel with a double click. I find that both views are useful depending on the situation.
