Author Topic: Long comments in m4a files are cut off  (Read 385 times)
fiso64
Long comments get truncated when editing tags in musicbee for m4a files. To reproduce:
1. Add an m4a file to the playing tracks list
2. Right click and click 'Edit'
3. Paste a long string into the comments section, e.g
Lorem ipsum dolor sit amet,
consectetur adipiscing elit,
sed do eiusmod tempor
incididunt ut labore et
dolore magna aliqua. Ut
enim ad minim veniam, quis
nostrud exercitation ullamco
laboris nisi ut aliquip ex ea
commodo consequat. Duis aute
irure dolor in reprehenderit
in voluptate velit esse cillum
 dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat
non proident, sunt in culpa qui
officia deserunt mollit anim id
est laborum.
4. Save the tags and close musicbee, and use another tool like ffprobe to display the comment. It will be cut off.
Here's the m4a file I used for testing: https://filetransfer.io/data-package/PXr3L307#link, it's just the output of
ffmpeg -f lavfi -i anoisesrc=d=240:c=pink -ac 2 -ar 48000 -b:a 256k -acodec aac white_noise.m4a
1. This does not happen in foobar.
2. bass_aac is in the musicbee directory, in case that matters
Version: 3.6.8922 P
it was an intentional restriction to maintain compatibility with iTunes by limiting 255 characters but i have removed the restriction
https://getmusicbee.com/patches/MusicBee36_Patched.zip
fiso64
Thank you. Long comments are common in mixes (for the track list), and the ones downloaded from soundcloud are in m4a format. A bit unfortunate that some of my favorites have been removed from soundcloud meaning I can't restore the track lists, but oh well.
