Author Topic: No Albums with certain custom tag  (Read 574 times)
Yuin
albums main panel should showing it albums display  if i tag instruments with Violin; Harp.
or maybe iam tagging it wrong ?
https://imgur.com/a/E464Dne
What MB version are you using?
And can you send a link to your settings file (help/ support/ view settings)
i cant replicate your layout as you are using custom tab views
Your screenshot is very confusing as the left panel header shows "Artist" but "Violin; Harp" is highlighted at the bottom. I am guessing you have another panel included with the panel header turned off, so can you let me know which type of panels are used
Yuin
iam using artist on left panel grouped by custom tag instruments.
if i click both artist name below Violin; Harp it will show album but not with Violin; Harp
here my custom instrument layout
https://filebin.net/oe07fdc3cimd2j4l
i edited image to show Violin; Harp to make it focus on problem area but make it confusing. sorry about that.
Last Edit: November 25, 2023, 11:03:22 PM by Yuin
This should address the issue:
Yuin
