Author Topic: how can i import this BBC radio live stream playlist to musicbee?  (Read 634 times)
mxpro
trying to import this bbc radio livestream playlist. downloaded it and its m3u format. how do i import it? not working atm.
the github link to this https://gist.github.com/bpsib/67089b959e4fa898af69fea59ad74bc3
MusicBee v3.5.8447.35843Store (Win10.0), 23 Oct 2023 5:45:
System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1.
   at System.Xml.XmlTextReaderImpl.Throw(Exception e)
   at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
   at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
   at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.XmlTextReader.Read()
   at #=z$LZhQEg_pPqnJ5PCX5a8w65q_bDMnoTXhA==.#=z1SUoTUU=(String #=zmptTIOo=, List`1 #=zmZz$2Bkz0KLac6m9Eg==)
   at #=z$LZhQEg_pPqnJ5PCX5a8w65q_bDMnoTXhA==.#=zX0U56uZy8qr_COzbMw==()
   at #=zLs3ic1eXqqFM6Y5Ob_4BZSTWtEGt.#=zRRsj_2RH$PX4.#=z8qYszyQbge56Ol3AHS0zciaN69c8(Object #=zNJBP6jk=, EventArgs #=zmmOoBdU=)
The import radio stations function expects an OPML (xml) file. You are attempting to import a .m3u playlist which is not supported by the radio stations import function
