Author Topic: Improve the quality of sound  (Read 1852 times)
wealstarr
Hello Steven,
I apologies for making a request knowing well that you are the only dev on this project and you have a real life too. But if you ever find free time and find yourself thinking what cool feature could I add to MB, please do something about the Sound Quality. This is the complain since the beginning when I switched from Winamp and so many years had passed nothing changed to the point I lost all hope.  But here I'm giving another try.
The other day, upon getting the news that AIMP now supports the VST natively without any extensions/plugins so I decided to give it a try. I plugged two of my most used plugins into it and loaded a random album, I'm telling you the truth, when it was playing, I did not wanted to turn it off. That's how good it was. It's the same album I rarely listen in Musicbee, if ever.
MusicBee is phenomenally good software that does things other softwares in the same realm can only dream of.
Please, if you have time, it will elevate MusicBee to the level of "Epic"
Kind regards
I think you are misunderstanding or at least misusing the term "Sound Quality."
Musicbee can output a bit-for-bit accurate reproduction of the source to the output device.  There isn't better sound quality than a perfectly accurate reproduction of the source material.
VSTs have nothing to do with sound quality besides degrading its accuracy.  They are used to sweeten sound to taste (which is what you're really asking for) or to compensate for equipment that can not accurately output the accurately reproduced sound that is input by the player.
