Author Topic: Again: How do you make musicbee copy files to the library folder when adding?  (Read 3757 times)
greatfox
How do you make musicbee copy files to the library folder when moving from inbox?
Select the files  > right-click > send to > folder > copy or move or replace > to folder or to organizer folder.
Ap0st0l
And thanks to that instruction I have now duplicated music files, ones are outside of the organized folder and others are inside it...
Isn't there any easy way to do that? I have the same problem every time I try to import anything.
[Edit] Ok, I think I get it... I should have these files on the same disk as a library before importing... Then MusicBee organizes it. If it's on other disk, I end up with files in 2 places.
Last Edit: October 08, 2023, 01:33:49 PM by Ap0st0l
