Hi, can anyone help me with this? When I add music to playlists in MusicBee, it automatically rearranges/jumbles the tracks in those playlists in weird ways. This started happening a couple of months ago in Windows 10 and continues to happen in Windows 11. The steps to reproduce the behavior are as follows - they're exactly the same for me every time:
- Create new playlist
- displayed fields: use default OR custom fields for this playlist only (makes no difference which I select)
- display using view: Default
- Add album (Logic - No Pressure) by dragging the tracks into the playlist from Windows Explorer
- Since my other playlist is in descending order, this album is, too; however, I don't want it to be. I can't just change it to ascending order, however; because then my other playlist will also change to ascending order. So, I rearrange each track manually so the album will play through from start to finish.
- Now I drag a second album (Them Crooked Vultures) in from Windows Explorer and drop it
above the first, at the top of the playlist
- For some reason it adds it below the Logic album instead
- It also rearranges the order of the tracks in the Logic album (the first album I added) so they go 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 14, 15
- Additionally, it adds the new album (Them Crooked Vultures) in ascending order (1-13)
- If I navigate to Sort > Restore Manual Order, it inverts the current list and also inverts my other playlist, which I don't want it to do, so instead, I have to reorder everything manually so "Them Crooked Vultures" is at the top, Logic's "No Pressure" is at the bottom, and all the tracks are in album order
- Now I add a third album to the end/bottom of the list by dragging it in from Windows Explorer
- This time, the first album I added (Logic) is actually split up: From the top of the playlist, it goes track 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, then the new album ("Best of Depeche Mode, Vol. 1"), appears in the correct order (1-18), then Logic's "No Pressure" continues but in reverse, 5, 4, 3, 2, 1, and then "Them Crooked Vultures" appears in descending order 13-1
This same behaviour repeats every time I follow these steps, and I mean exactly, down to the track numbers, where Logic's album splits in half, etc.
Anyone got any ideas what might be causing this?
