Author Topic: Visual Glitch in Auto-DJ  (Read 855 times)
Using 3.5.8167 P.
At the very bottom of the Auto-DJ config window  I can see part of what appears to be a header row. I can not get the cursor to a vertical "mover." But it does change to a horizontal "mover" when positioned near a column field.
is it reproducible and if so what steps did you take
Very much so.
Open MB > click Auto-DJ (under Playlists) in left sidebar.
This is before I enter any criteria, and even when I do. I -think- it's the Auto-DJ preview.
I have the "playing tracks" panel at the bottom of the main panel. If I remove that, then the partial headers are visible. So it looks like the playing tracks panel needs to be resized.
With playing tracks panel at bottom:
With playing tracks panel removed from bottom:
It should be letting you resize the panel. Thats fixed for the next update
Thanks.
