So, unless I needed MB to be used by multiple users in Windows (not my case), basically portable is better as everything about the software is in the same folder which I can just back up as it is, and in case I needed to reinstall I just copy the whole folder and everything will be as it was?
If so, that's great! Now, If I wanted to move to portable, now that I have set every single thing in my MB, should I start from scratch or I can import settings, views, library from installer to portable?
