Author Topic: Problem when editing tags in App ****\@restorespecialchars[[**** [SOLVED]  (Read 950 times)
SpirosG
Hi evyrtime i edit a tag inside musicbee this is what appears to the title
 \@restorespecialchars[[\@repunct[[\@escapespecialchars[["Title" ]]]]]
How can i fix this?
Last Edit: September 30, 2019, 09:13:56 PM by SpirosG
MB version? Help > About
Does it show before of after you edit? In other words, as soon as you open the tag editor?
How are you editing the tags? Step-by-step please.
Can we see a screenshot of what appears? (see my sig)
How did you acquire the files you're attempting to edit? I.e. Ripped from a CD, downloaded from an online source?
SpirosG
3.3.7165 Store
No it shows when i save the tag
In musicbee either right click and then edit the tags either inline tag editing will have the same result
From an online Source. It Happens in every tag i edit within the app.
Solved
In advance tagging tools i propably accidentaly clicked in replace Unicode punctuations marks by Ascii
Last Edit: September 30, 2019, 09:13:24 PM by SpirosG
Take a look at the edited/saved tag using the Tag Inspector (it's a tab within the Tag Editor)
Does this also happen if you're tagging something that you ripped from a CD?
What does the tag look like before you edit it?
I don't recall anyone bringing an issue even close to this. So I suspect the file and/or its source. I don't think it's the Store version of MB, but you could download the Portable version and see if the same thing happens. If it doesn't, that would eliminate MB as the cause.
update tag tools plugin to the latest version. i assume it doesn't have this bug.
