Author Topic: Remove a mood from MusicBee's drop down list?  (Read 1922 times)
EuroMIX
I have two junk moods that serve no purpose to me that show up in MusicBee's drop down list. Is there a way to remove them?
alec.tron
If it's a custom mood value you have set - you need to remove the value from the files/database - when there's no files with the vaules anymore then they will also be removed from the drop-down list.
If it's one of the MusicBee standard mood values, you can probably remove it from the Configuration xml file, but that's just a guess on my end.
c.
