Author Topic: Need Help getting my player back to the way it was....  (Read 1613 times)
SweptbackFlame
So I had to recently get my harddrive replaced and had to download musicbee again, I had my layout set a specific way and I can't figure it out for the life of me on how to get it to the way it was...
If someone could guide me that would be awesome. So basically this is what I want.
Right now the main left panel is an expand list of the artist/years/albums. I don't want that. I want it just to be the artist.
And the Genre/Year/Publisher in a list in 3 separate panels. Above the Main Panel.
Just found an image from an old post on here that I posted. This is the layout I'm talking about.
Any help would be greatly appreciated it. is driving me absolutely nuts!
Last Edit: July 18, 2017, 04:46:01 AM by SweptbackFlame
See if this helps: http://musicbee.wikia.com/wiki/The_Anatomy_of_MusicBee
If not, a screen cap of your current config might be helpful, too.
SweptbackFlame
Yeah it didn't really help me. to be honest. :(
here's my current config.
Currently you have library explorer in the left main panel and if you meant you want to have thumbnail browser there, then replace it with that.
Also add column browser to the main panel with horizontal layout. If you right click on its column header> Set Displayed Fields, you can adjust displayed fields.
SweptbackFlame
Ok got the Columns to show. Now I just need the left main panel to stop expanding into sub categories when I click on said artist.
Nevermind, I figured it all out. I appreciate it!
Last Edit: July 18, 2017, 10:08:47 PM by SweptbackFlame
