Author Topic: Post Upgrade Help... please :)  (Read 1210 times)
RLTIOW
Hi, I have used version 2.5 for a while and today decided to upgrade to version 3. Looks lovely but i do have two issues. I use compact view tucked into a corner of my screen but it is significantly wider then on the previous version. Can i make it narrower? Also, i cannot display album art in my Compact View. I know the art is there as i see it on other views. All i want to see is the Album cover, currently i just have 'Large Album' selected.
Any ideas?
thanks
RLTIOW
OK, so the Album Art is fixed now. I went through a few cycles of selecting and then deselecting various options and I now have the Album Artwork as I wanted. There is possibly a bug in there somewhere but I am not up to finding it. The compact player is still way wider than the previous version, is this just how it is or can i slim it down?
thanks
