Author Topic: Can't add library files to playlists...  (Read 243 times)
sfermano
I can't add music files to playlists...I tried dragging and dropping with no luck and also by right clicking on the music file and selecting add to playlist...
I get the following error message...any help will be greatly appreciated...
MusicBee v3.4.8033.18564D  (Win10.0), 23 Apr 2022 16:14:
System.IO.IOException: The operation completed successfully.
[C:\Users\Steve\Music\MusicBee\Playlists\Easy Listening.tmp]
   at #=zZStC9iyBHabrHQWBQanCD08=.#=zdvAqALsrI53x.#=zP5LfWjQ=.#=z$Pp$u_2H_lVe(#=zqTU3nglKnwb8VWp94Q== #=zaFVWxMw=, FileMode #=zaWjtin8=, FileAccess #=zxNilYKc=, FileShare #=zJ$E2MGA=, Int32 #=z6F8SGak=, Boolean #=z2E03uDlVJHtH)
   at #=zXVYVwVH6SkdTLBeauePxIjUNJoI6.#=z$Pp$u_2H_lVe(#=zqTU3nglKnwb8VWp94Q== #=zaFVWxMw=, FileMode #=zaWjtin8=, FileAccess #=zxNilYKc=, Int32 #=z6F8SGak=)
   at #=zYfpcHehNrIPwD8iNST8MxN4=.#=zZupEvOk=(List`1 #=zgJymtQ8=)
   at #=zYfpcHehNrIPwD8iNST8MxN4=.#=zYzsp$4w=(IList`1 #=zgJymtQ8=)
   at #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=zdU4doGGRdlcB(#=z7RwQyW8Th6QHsV0jbT0LtTw= #=zlcjZ9tc=, List`1 #=zgJymtQ8=, List`1 #=za8iResUYUQeF)
   at #=zZayNzbiQusTiMxpjyrnkLZz66MZF.#=zX02ezio=.#=z9v$T9WY=(ApplicationCommand #=zWDWB1Kc=, Object #=zpiS1AD4=, IList`1 #=zgJymtQ8=)
   at #=z9xpOhZZF8416QDRVkDgFBYAbLk3$.#=zx_yFi5E_IccxGLP7Ag==(Object #=z09rm0$E=, EventArgs #=z5EKpxKY=)
are you able to create a file yourself using windows explorer in C:\Users\Steve\Music\MusicBee\Playlists
also your security software might be blocking MB, so try whitelisting MusicBee in that app
sfermano
This is what I have in that Users folder...not sure though what should be there or what I should do with any of them???
4 Folders
Classic Rock.tmp
Easy Listening.tmp
playlist.mbp
playlist.tmp
4 Files
Beatles.mbp
Classic Rock.mbp
Country.mbp
Easy Listening.mbp
Instrumental.mbp
Oldies.mbp
Recently Added.xautopf
Top 25 Most Played.xautopf
I tried to copy and paste a jpg photo of exactly what it looks like, but it wouldn't paste here?
