Author Topic: Seem to Have Messed Up How 'Enter' Works in MusicBee  (Read 368 times)
MollyRealized
  • Bookworm who likes the surreal & silly.
So, I have MusicBee set up so that if I hit the Enter key, it starts the song that is currently selected.
The problem is, by doing so, if I hit Enter while a menu option is selected (say, Alt-F for File Menu and I've arrowed down to Quit), it doesn't select the menu item, it starts the song.
How can I do one without the other?
Why not just left-click your mouse on the choice on your file menu, instead of hitting Enter?  Once you've assigned "Enter" to another operation, that's the only thing you're going to get with it.
MollyRealized
I'm on a laptop with a trackpad - truly not as intuitive a gesture.
