Author Topic: CUE sheet with OPUS file  (Read 1237 times)
Barafu Albino Cheetah
Are CUE sheets with OPUS files not supported? When I try to drop such a file onth INBOX, it shows individual tracks, but does not play them when I doubleclick...
Roby
Have you checked that the syntax of the .cue file is correct?
I assume yes, because the same file does work if I replace the file with flac.
FILE "filename" WAVE
TITLE
and so on.
