ok tried Patched version, and now Music Bee opens again, but all of my files are marked with the blue exclamation point...what is happening?
thanks
edit:
oh the version that opens is the shortcut from clicking on mp3 files, version 3.0.6347.
The version that is in ProgramFiles(x86) doesn't open, 3.1.6338. Too many versions around, confusing, sorry.
Does it matter where the installer is, should it be in the Music Bee folder?
This actually happened before I upgraded in the first place. Trying to be cautious, I copied the files in the Library folder (not the music files, all of the other ones) to another folder, and that is when the blue exclamation points first showed up. I decide, oh well, I would upgrade then, and, lo & behold, the files showed up as in the library. All was well except for the inbox count. Then when I installed the more recent versions, Music Bee stopped opening completely.
Now, I have a version that opens, but it doesn't have the library.
That is, it has the correct path, and it still knows the Date added (which is what I hope to retain), but they are not in the Library anymore. Is there are way to get them into the library with the original Date added?
Does this make any sense at all?
