Author Topic: Synch then all playlist are empty  (Read 1994 times)
spike12
I just got a new microsd card and copied everthing over to a new bigger card.  Everythign worked fine.  Then I made a new playlist on music bee and now all my playlists are empty. my phone is a moto G7 power if that makes a difference.
I suggest you read through this thread: https://getmusicbee.com/forum/index.php?topic=33418.0
Even if your problem isn't exactly the same, it outlines important troubleshooting steps. If you can't solve the problem based on that, then let us know discuss where you found the problem (playlist for, reading them into the player, etc)
