Author Topic: List of static playlists  (Read 8856 times)
Pako
I can get (using API) a list of playlists. It is simple.
However, I would need to get a list of only "static" playlists (created by the user as "Playlist" or using "send to: <new playlist>").
Is it possible?
Thanks, Pako
No, but you can get playlist type with mbApiInterface.Playlist_GetType(playlist)
Pako
Oh, thank you. This function returns (enum) PlaylistFormat.
So I have two additional questions:
1) Static playlist format is always MBP?
2) Other playlist (than static) is never MBP?
If the answer to both questions is yes, then my problem is solved.
Note: I'm interested solely on the playlists that are displayed in the navigation panel.
Thanks, Pako
Anything that is not:
PlaylistFormat.Smart
PlaylistFormat.Radio
is a static playlist
Pako
I'm very sorry, but I did not understand your response.  :(
This is certainly due to my poor English.
In addition - I do not know the "smart playlist".
In my version of the API does not exist.
Can someone please clarify?
Pako
'Smart' is auto playlist.
'Radio' is playlist mixer.
All other types are static playlists
mbApiInterface.Playlist_QueryPlaylists()
loop begin
  playlistUrl = mbApiInterface.Playlist_QueryGetNextPlaylist()
  if playlistUrl is null then exit loop
  PlaylistFormat format = mbApiInterface.Playlist_GetType(playlistUrl)
  if format <> PlaylistFormat.Smart and format <> PlaylistFormat.Radio
      //  this is a static playlist
  end if
loop end
PlaylistFormat.Smart refers to auto-playlists
Pako
I thank you (boroda74 and Steven) very much for your explanation and patience.
Now I'm completely clear.
Only the "smart" I really can not use:
        public enum PlaylistFormat
            Unknown = 0,
            M3u = 1,
            Xspf = 2,
            Asx = 3,
            Wpl = 4,
            Pls = 5,
            Auto = 7,
            M3uAscii = 8,
            AsxFile = 9,
            Radio = 10,
            M3uExtended = 11,
            Mbp = 12
Somewhere I can download a new version of the API?
Pako
all of the functions have been in the API for a long time so you should already have access to them.
if you want static playlists only then you need to exclude Radio and Smart
Pako
It seems that I am in this case "slow on the uptake," or we "talk at cross Purposes".
I understand practically everything.
Just my "Microsoft Visual C# 2010 Express" will not let me write the expression "PlaylistFormat.Smart".
This is not possible because the "Smart" does not exist in the enumerator "PlaylistFormat".
So I can add it there?
What integer I have to assign it?
Or should I replace the "Auto" item?
I'm very sorry and thank you.
Pako
Yes it seems that ".Auto"  is auto-playlist
Pako
I thank you very much, you saved me. Everything is therefore as I assumed ....
After all - this works as expected:
        internal string pQueryPlaylists(bool stat)
            if (mbApiInterface.Playlist_QueryPlaylists())
                string f = "dummy";
                Dictionary<string, string> dict = new Dictionary<string, string>();
                string name = String.Empty;
                while (f != null)
                    f = mbApiInterface.Playlist_QueryGetNextPlaylist();
                    if (f != null)
                        if (stat) {
                            Plugin.PlaylistFormat pf = mbApiInterface.Playlist_GetType(f);
                            if (pf == Plugin.PlaylistFormat.Auto || pf == Plugin.PlaylistFormat.Radio) { continue; }
                        name = mbApiInterface.Playlist_GetName(f);
                        if (!dict.ContainsKey(name)) dict.Add(name, f);
                return Dict2Json(dict);
            return String.Empty;
Thanks again, Pako
