nothing has been changed for a long time with this, so i expect its something specific to your skin. Can you PM me a link to it
Looks like it takes PlayerFlat elements for most elements except player controls and not loved icon which comes from sidebar player. Can you make it use all from PlayerFlat elements?
@iasc, i cannot see the dot you describe using the skins you sent. Can you post a screenshot using Absolute Zero ?
thanks. Its actually due to whether the width is even or odd numbered. Very strange. But i have put in handling for that for the next update
Quote from: redwing on April 15, 2016, 06:48:54 PMLooks like it takes PlayerFlat elements for most elements except player controls and not loved icon which comes from sidebar player. Can you make it use all from PlayerFlat elements?although what you say is logical, i dont want to make a change at this point that may impact other skins. I can do this for v3.1 if you put it as a wish on the 3.1 skin requests topic
those overrides havent been supported for the entire time of MB3.
when tabs bar is in caption bar and toolbar buttons are shown in a separate bar bothTabsBar.BorderLine andTabsBar.TabInCaptionBar.BorderLine
