Author Topic: Search for embedded artwork filetype  (Read 1747 times)
Anti
I didn't pay any attention whether the files were jpg or png when embedding artwork into my library.
Now I've discovered that my mp3 player does not display png artwork.
I'd like to identify all the files in my library which have png embedded, so I can embed jpg instead.
Is that possible in Musicbee? Maybe a 3rd party tool?
Also, now I can't easily use Musicbee's 'search for picture on internet' feature, because until it's
actually embedded, there isn't a way to opt between jpg or png. Any solution for that?
Thanks.
there isnt a way to search the library, but when synching, if you force picture reszing then MB will encode the resized pictures as JPEG
Anti
