Author Topic: Mellon Remix  (Read 35125 times)
This is my rework of Bee-liever's Scamelon skin, based on the original Mellon skins for Media Monkey by DreadM.
UPDATE, 4-8-16: I've done a big overhaul.  I referred back to the original Mellon skins and took advantage of new MB skinning elements to capture more of what I liked about them.
This skin will look best with either tabs in the caption bar OR the panel header bar hidden.  If you want the same look in a another configuration, it's easy to do.  Just let me know.
Download here:
https://app.box.com/s/fca2dsy99q7uw1zdosgqhmizhh2w2fk3
Mellon Remix 3.0 requires MusicBee 3.0+.  The 2.x versions of the skin are still available here:
Classic version: https://app.box.com/s/1hek3quqh0rgo9o0wnud42w4b7fps19a
*Rounded window borders
*Scrollbar arrows
Modern version: https://app.box.com/s/2ti68kr2hqscjsdudy0d
*Square window borders
*No scrollbar arrows
Regarding the icons, I happened to make a lucky find while looking for custom toolbar icons.  If you'd like to have matching left panel and toolbar icons for this skin, you can find the full set here: http://dryicons.com/free-icons/preview/pixelistica-blue-icons/
Thanks to Bee-liever, redwing and jistme for help in making this work.  Comments, questions, requests, etc welcome!
Last Edit: April 10, 2016, 05:45:07 PM by psychoadept
Why thank you.  And thanks for tweaking some of the elements in the process.  :)
Iasc
jistme
Nice, you've gotten my brain in a twist.
I think I don't like the colors, but I do like the skin???
Well done!
  • MB Version: 3.6.9255 P
Ah. You do make it hard scampbll  ;)
I like what you've done with the skin, especially the violet border, and the work on the icons. Truly inspired re-use of the splash screen for missing artwork.
I'm just not sure on the stripes  :D
You do know that you're now gonna have to do the bitmap player version as well   ;D
Thanks!  I don't know why, but I'm attached to the stripes.  Maybe just cause I was used to them.
The bitmap version... I know, I know... ;)  I doubt I'll really feel done until I do it.  Which is ironic, since I typically use the sidebar player.  It's the principle of the thing.
Last Edit: May 27, 2013, 12:40:29 AM by scampbll
I'm also intrigued to see what your re-imagining of it will look like!
Made a few tweaks, particularly to Artwork view.  Link is the same.
Updated to elements in MB version 2.1.4907
Further updates, to 2.1.4909.
A few minor updates.  Feedback on the change to right sidebar header is invited.  :)
Updated to 2.2.5012
