Author Topic: Traditional Chinese  (Read 39636 times)
This Traditional Chinese localisation is kindly provided by tmdicky:
http://www.mediafire.com/?n5y50f4m2odnfn4
save this file to the Localisation folder where musicbee is installed and select from the main preferences panel
tmdicky
v2.1.4905 Traditional Chinese localisation can be find here:
http://www.dickyspace.info/projects/musicbee/TC.zip
Unzip the downloaded file and place the .lng file under the Localisation folder in your MusicBee install directory.
tmdicky
Traditional Chinese localisation for MusicBee v2.2 can be found here:
http://www.mediafire.com/?a82vcoa8wr4s4e4
Unzip the file and put the .lng file under the Localisation folder in your MusicBee install directory.
tmdicky
Traditional Chinese localisation for MusicBee v2.3.5161 can be found here:
http://www.mediafire.com/download/wb3v0q5a3dbnzb6/TC.zip
Unzip the file and put the .lng file under the 'Localisation' folder in your MusicBee install directory.
Last Edit: February 21, 2014, 07:20:31 AM by tmdicky
tmdicky
Traditional Chinese localisation for MusicBee v2.4 (RC1) can be found here:
http://www.mediafire.com/view/t1x000ivtpvz1bz/Traditional_Chinese.lng
I also updated the simplified chinese localisation to v2.4 (RC1), you can get it from below link:
http://www.mediafire.com/view/82b18acm5u2gpyq/Simplified_Chinese.lng
Save the file to the Localisation folder where MusicBee is installed.
thanks tmdicky, and also thanks for the simplified chinese as zzh1989829 is finding it difficult to spend time translating it now.
the binary files are uploaded now:
http://musicbee.niblseed.com/Weekly/Localisation/Traditional%20Chinese.lngc
http://musicbee.niblseed.com/Weekly/Localisation/Simplified%20Chinese.lngc
tmdicky
Updated the localisation files to version v2.5.5516 (RC1)
Traditional Chinese
Simplified Chinese
tmdicky
Updated the language files for MusicBee 3.0 RC1
Traditional Chinese:
https://www.dropbox.com/s/rju9bn584c980cn/Traditional_Chinese.lng?dl=0
Simplified Chinese:
https://www.dropbox.com/s/q7a6y6rlb48h41h/Simplified_Chinese.lng?dl=0
tmdicky
Updated the language files for MusicBee 3.1 RC1
Simplified Chinese:
tmdicky
Updated the language files for MusicBee 3.2 RC2
Simplified Chinese:
thanks tmdicky, those will be included in the final v3.2 release
