Author Topic: Artwork dimensions as a usable field  (Read 8551 times)
Why not put artwork dimensions in an automatic field, sort of like kind or playlist?  If there's no artwork, it would be blank.
It would eliminate the need for the small artwork filter entirely (we could make our own, if we wanted one), and would simplify finding tracks that have no artwork.
paq
How would it work if you have more than one artwork linked to a file? Should it only retrieve the values for the primary picture?
I would think it would use the one marked as the main picture.  What does the small artwork filter now do?
Still really hoping for this.  I can use the small artwork filter to find artwork that is less than X size, but what do I do if I want to find artwork that's bigger than X size?  (Or, actually, with what I want to do now, that's not *exactly* X size.)
With the increasing availability of high quality artwork, such a field would make the task of managing artwork a lot easier.
If not, then please provide a way to detect the presence of artwork with a track like <artwork?> field. Or, allow to use "<artwork><has no value>" rule for auto-playlists and filters for the same purpose.
Pingaware
+1
