Author Topic: Better Capitalization Tool  (Read 12602 times)
Squeak
Currently the capitalization tool (Tools>Tagging Tools>Capitalise) capitalizes the first letter on all of the words in the various fields but this is not actually correct capitalization with regards to titles. Articles, conjunctions, and short prepositions are not capitalized unless they are the first or last word in the title (Source: http://aitech.ac.jp/~ckelly/midi/help/caps.html).  So a song titled "tip of the hat, punch in the face" becomes "Tip Of The Hat, Punch In The Face" when it really should be "Tip of the Hat, Punch in the Face." It's slightly a trivial problem but seems like it wouldn't be all too hard to implement.
jistme
That's easy to say if you don't have to implement it...
Yet since I also waste quite some time correcting titles in this manner;
+1
Squeak
I know, I know! I actually deleted something saying "As a non-programmer it's always awful to say but..."
Forum member Boroda74 has created a plugin which includes a customisable case conversion tool:
http://getmusicbee.com/forum/index.php?topic=3833.0
It's a great tool to do what you're trying to do, but I suggest you experiment on one or two files before you use it to make wholesale changes.  You want to make sure you've got the correct parameters set up.
jistme
Seems like a good suggestion.
Before I put some work and exploration in that, do you think it is possible with Boroda's plugin to accommodate about everything that is suggested here: http://aitech.ac.jp/~ckelly/midi/help/caps.html ?
For example, would it be possible to create a rule so that "a bad attempt in putting on a smile" will become "A Bad Attempt in Putting On a Smile", and not "a Bad Attempt on Putting on a Smile"?
Based on the options in the screenshot, it doesn't look clever enough to handle phrases like "Putting On". :(
(nice succinct list of rules on that page, btw)
But still doing a good job except the phrasal verbs rule that could be better handled manually.
jistme
Looks good.
The main missing feature then seems to be the option to 'always capitalize the first word', even when it's in the list of exceptions.
jistme
Squeak produced the url.
For 'our' purposes it would have to become even longer.
For e.g. "Beat Up" and "Blow Out" from that list, also "Beating Up", "Blowing Out", "Blown Out", etc. etc. would gave to be added.
And then we're just only talking English language...
Looks good.
"first or last word" according to the rule #2?
2. These are lower-case, unless they are the first word or last word.
articles: a, an, the
conjunctions: and, but, or, nor
prepositions that are less than five letters long: at, by, for, from, in, into, of, off, on, onto, out, over, to, up, with
as (only if it is followed by a noun)
Looks good.
You can make 2 or more steps (without writing changes to tags) by changing rules and clicking 'Reapply rules' button. For instance, to achieve desirable titlecasing for sentence 'a bad attempt in putting on a smile':
1. Sentencecase a, in, on, etc.
2. Titlecase all words except for a, in, on, etc.
You'll get 'A bad attempt in putting on a smile' on the 1st step and 'A Bad Attempt in Putting on a Smile' on the 2nd.
In your example wouldn't the "A" at the beginning of the title wind up as lower case?
No, excepted words remain unchanged, not become lowercased (this is not obvious, but this is how plugin works).
