Author Topic: A Sophisticated Bee  (Read 65995 times)
jistme
My take on a comfortable and well-behaved skin.
(no loud music on this one please!)
There are two download links:
- Skin version 2.5 which is compatible with MusicBee v2.x releases.
  This one is final and will be no longer maintained.
- Skin version 3.x which is only compatible with MusicBee v3.x releases.
download A Sophisticated Bee 2.x
download A Sophisticated Bee 3.x
edit Jan 2016:
The version for MB 2.x is finalized and won't be maintained any longer, a new version for 3.x only is added.
Please feel free to comment, be it good or bad.
Last Edit: June 12, 2022, 07:04:19 PM by phred
beeing good
Very nice Jistme, I like what you've done with the selection highlighting.
  • MB Version: 3.6.9255 P
Nice work again jistme.
Very restrained and understated.
The splash screen made me chuckle though, very "old world"
Iasc
really like this. i have been looking for a nice light skin. thanks
jistme
Yeah, but it might fit your Bee78 better ;-)
Btw, don't chuckle out loud, his hearing is still 20/20, and he might feel offended and defend his honor properly.
http://i.imgur.com/MR1nQ.jpg
jistme
Thnx, I was also triggered a bit by a suggestion/request from somebody (maybe you) a while back for an 'easy on the eyes' light skin to do some mileage on.
I made 'Jistme on the Outlook' for that purpose, but I suppose after a while you might get some slight blue poisoning from that one.
Last Edit: August 30, 2013, 06:20:56 PM by jistme
jistme
Small update: 'feature enhanced' repeat and shuffle buttons.
jistme
Small update: set override text and background color for new Album view.
(MB v.2.1.4731)
jistme
Updated
(support for new spectrum visualizer in Now Playing panel)
jistme
sierena
jistme
Updated.
No big changes at first glance, but a vast amount of small fixes and improvements.
A request to the experimenting types with some spare time on their hands;
Please give it a test drive with different settings and layouts. I completely revised the xml, and if this is working well, it will also be the template for my other skins.
(it would be a pity if any possible flaws would be copied to those too)
Thanks in advance!
download 'A Sophisticated Bee'
Last Edit: March 29, 2013, 01:01:42 AM by jistme
Love that blending on the Player display panel, and the Command buttons just pop, but it's those repeat and shuffle buttons that really get me. I still think they are one of the best (if not the best) designs anybody has come up with for their skins.
jistme
Thnx Bee-liever.
So not stumbling onto any bugs either?
- "just pop" is good, right?
- I have yet some doubts about the vertical placing of the shuffle/repeat icons. Maybe better make it horizontal? (like I did in 'Ebony and Ivory')
I'm still waiting for your (no-doubt even more creative) implementation of such sort of shuffle/repeat buttons...
