Say, you want to use a specific settings of track browser (and library explorer) for a certain filter (say, classical music) and another settings for another filter.
It seems that the current "view settings" saves a specific view (artwork, album& tracks, etc.) and column settings only. To save a certain track browser and LE settings, you have to resort to using different "layout settings." But that requires a restart and you don't want to change whole a lot.
Hence it would be great if "view settings" can save track browser & LE settings in addition to the current save. Then users can easily shift to a different track browser & LE settings using filters and auto-playlists. And that change wouldn't matter to those who don't use track browser and LE because the settings will save it simply as being OFF.
Moderator's NoteMerged with the thread "Track browser configuration associated to customized views"
by user "Greb":Right now it's possible to save different views through the 'copy current view setting to...' option.
But all the different view share the same track browser settng: same number of columns and same column selected.
Would be it possible to select a customized track browser configuration for each customized view? This way, you can associate a Genre/Album Artist track browser for one view, an Album Artist one to another one, a Artist one to one view you want to see every artist (and not only album artist) you have, another one by Year, and so...
