Author Topic: MetroTouch  (Read 40174 times)
  • MB Version: 3.6.9304P
ATTENTION!
Maintenance of this skin has ended.
The replacement skin for MB3.0 is available here.
Go To Finalised Version in Reply #13 >>
With apologies to lnminente
Rough trial of a touch screen version of MetroColours as requested by joebanana
MetroTouch
Made on MusicBee 2.1.4716
Download  see Reply #13 in this topic
Installation guide (if needed) is available here
I don't have a touch screen, so if joebanana, or anybody else, would test this and leave some feedback, before I clean the images up and do the rest of the Metro colours
 8)
Last Edit: February 16, 2016, 03:33:46 AM by Bee-liever
joebanana
Works very well.
I won't comment on the look as of yet since you mentioned you would work on them.
I would LOVE if you coul give the buttons a more modern look. Actually, a Metro look would be awesome.
And finally, I like a light theme (i use Metro Light Cyan) so if you could keep the same colors, that would be definetly wicked.
Do all that, and I'll have a x-mas present sent your way :D
I would LOVE if you could give the buttons a more modern look. Actually, a Metro look would be awesome.
When you say Metro, are you talking Win8 Metro (now Modern), similar to my Wing-ated skin, or are you talking Metro/MetroColours?
A pic, similar to what you would like to see would be great, if you can find one.
joebanana
No I was more thinking something like this:
Gotcha!
I can do a bit more work on this now
mtone
Perhaps an interesting design for buttons would be Metro apps' toolbar style (when you right-click the app to access the menus). They're touch friendly, clean, and could be transparent over a dark color unless set to "on" (eg. Play when playing).
I also like that the color of active buttons is only inside the circle - much cleaner than a huge bright blue square in my opinion.
Here's a screenshot of the Metro Reader app:
Thanks for the info mtone
I'm still working through ideas fro this, and as the only touch screen device I have is my phone, it's great to get some other input.
joebanana
Exactly, I like that very much!
Grim944
I got this skin for my the PC in my car.  It looks great.  Please keep a dark color choice.  Bright colors are hard on the eyes at night.
Is it possible to make a playlist selection button or area that can be touched easily?
It's not a current option available in the bitmap skins.
You make the request in the Wishlist, and if Steven makes good with it, I'll add it in.
And I'll be doing a light and dark version  :)
Last Edit: December 07, 2012, 11:38:25 PM by Bee-liever
BinghiFire
Windows 8 use the Segoe UI Symbol font for the icons in the metro ( modern ui ) App's ,
nice and clean ,as i know there are saved in the SVG format.
Here is a nice visualization of the icons :
Segoe UI Symbol image
lnminente
No apologies Bee-liever, i declare all my skins open source since now. If need any source image not released just tell me.
Thanks lnminente. (although still don't feel 100% right, messing with anothers hard work and creativity  :-\ )
Unfortunately, it's not open source and you have to buy a licence to use it any redistributed software. Freeware or other.
ATTENTION!
MetroTouch
Amethyst
Blood Red (was original Red)
Byzantium
Cyan
Fulvous (was original Orange)
Green
Grizzly
Kelly Green (was original Green)
Mikado Yellow (was original Yellow)
Orange
Pink
Razzmatazz (was original Pink)
Red
Sapphire (was original Cyan)
Skobeloff
Yellow
All skins in one .zip file; Download Here
A big thanks to lnminente for his work on the original skin.
Updates
October 28, 2014:
  • MusicBee 2.4 updates incorporated;
  • Reduced variation of colour within skin;
  • Additional minor use of highlight colour;
  • Re-named 6 existing colours to their closest HTML colours:
  • original Cyan  now  Sapphire
  • original Green  now  Kelly Green
  • original Orange  now  Fulvous
  • original Pink  now  Razzmatazz
  • original Red  now  Blood Red
  • original Yellow  now  Mikado Yellow
  • Re-made original colours in true named HTML colours;
  • 4 new colours added.
March 1, 2014:
  • Minor change to remove some red borders made visible by MB2.3 changes.
January 17, 2014:
  • Changed icons;
  • Changed text colour;
  • Compact player and Mini-player changes incorporated; you will need to be using Vers2.3 for full effect.
December 16, 2012:
  • All of lnminente's standard colours finished.
December 13, 2012:
  • Minor change to track text handling and use of space when player bar is stretched with large fonts;
  • Pink version added.
Last Edit: February 16, 2016, 03:34:32 AM by Bee-liever
Havokdan
 :D :D :D :D :D   Many thanks, how i change yellow to blue/red/green?
