Author Topic: UPNP  (Read 138809 times)
poictesme
 ;D  Yes, that worked perfectly, Thanks a mil!
As for the TV issue, it may have something to do with the
HDMI pass-through function;  I don't much about that stuff
unfortunately.
The TV is switched on by MB when I start the programme too,
if that is of any help.
An now for some positive reinforcement... 2048 monetary bits coming your way.
Thank you for all the hard work you're putting into this.
i really have no idea what the TV thing could be, but could you confirm that if the plugin is disabled and you restart MB, does it still happen?
sambice
Thankyou, thankyou, thankyou, Steven.
I just discovered UPnP had been implemented with the 2.5 beta (I was one of the people requesting it a few years ago).
On first try it works flawlessly out of the box (as I've come to expect, as even the beta's you release are so damn reliable), I'm in MusicBee DLNA paradise!
MB as DLNA server to a Nexus 5 and Asus Transformer tablet (via BubbleUPnP).
Rendering to TV/Hi-Fi setup (via XBMC)
Rendering to Xbox (360, but not the Xbox One)
Flac files even all have cover art, which is something I've been struggling with for ages; and MusicBee as a server is way faster than the Twonky server on a NAS I've been using, scrolling long playlists was lag city, now it's not. Geat stuff, mate, thanks.
beastiegirl
First, thank you for DLNA in MusicBee. I have been coming back every few months for some time to see if it happens to work. :D
I have a WDTV and get an XML error in the Upnperrorlog when I guess it is trying to discover the device:
73; 7 NewMediaRendererDevice:http://192.168.1.39:52844/ - Root element is missing.
73; 8 ControlListen - Root element is missing.
73; 9 ListenNotify - Root element is missing.
Here is the exact XML response musicbee is receiving from the device: http://www39.zippyshare.com/v/94589493/file.html
Also in the Upnp log I found "Only one usage of each socket address (protocol/network address/port) is normally permitted." a few times. I use the awesome MusicBee Remote plugin by kelsos, and it listens on a port too so I'm not sure if that is the conflict or what. ???
Happy to re-beta-test if needed.
@beastiegirl, the xml file you sent is valid but the error log indicates musicbee received no xml file at all. I assume you got the xml file by entering the web address in your browser.
I wont be able to help you any further with this
poictesme
It was happening only if the plug-in was enabled, but it does not seem to be happening
at all with build 2.5.5447.  Whatever you did, "do not touch the candle, Inga".
Now, I might have followed a slightly different power up sequence and I will let you know
if things change, but afaict all is good now.  ;D
Thanks again.
MichaelP
UPNP & DLNA in MB 2.5.5447 plus UPNPlugin...
1. Serverfunctions nearly perfect, only a little restrictions i found: No Cover Album shown for current track, small pics in tracklist are o.k.).
For test I use Androit Tablet or iPhone with Yamaha-App and the Library ist structured \Interpret\Album\Tracks.mpg(s) plus Cover.jpg - perhaps my config is not o.k.?
2. Streaming audio direct from MB, Windows-PC to Yamaha Receiver don´t works in the moment for me -
I could select Player, device is found by MB as "RX-A2010". but play button in MB produces
message "Device ´RX-A2010´ is not ready for output" - was is wrong?
(of cource, the receiver is in "PC Input" mode and idle & without concurrent streaming).
I´m not really sure I made a correct Plugin config ::), I take some screenshots- send separate(?) - if wanted & helpful...
Thanks to Steven for his great work & greetings from Germany, Monheim
MichaelP
PS: Perhaps later it is useful, to implement a Device button for outputs in the Main Menü of MB.
In my opinion change client in Menu "Bearbeiten - Einstellungen -Player" is a little  inconvenient...
can you enable debug logging at the bottom of the UPnP plugin configuration dialog and after restarting MB and attempting output to the device then send me the log information
MichaelP
Thanks for reply  - I hope, these are the correct informations from UpnpErrorLog.dat:
02.12.2014 18:03:09; 1 GetNetworkAdresseses - id=LAN-Verbindung,speed=1000000000
02.12.2014 18:03:09; 2 GetNetworkAddresses - 192.168.100.111,dns=True,trans=False
02.12.2014 18:03:09; 3 GetNetworkAdresseses - id=Teredo Tunneling Pseudo-Interface,speed=100000
02.12.2014 18:03:09; 4 MediaRendererDevice - http://192.168.100.111:49382
02.12.2014 18:03:09; 5 ProcessMessage - device 'uuid:9ab0c000-f668-11de-9976-00a0de87b3ed:RX-A2010',valid=True
02.12.2014 18:03:09; 6 Activate - RX-A2010:http-get:*:audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=32000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=32000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=88200:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=88200:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=96000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=96000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=64000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=64000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=22050:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=22050:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=24000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=24000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=16000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=16000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=11025:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=11025:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=12000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=12000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=2;rate=8000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;channels=1;rate=8000:DLNA.ORG_PN=LPCM,http-get:*:audio/L16:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_192,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_192,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/x-ms-wma:*,http-get:*:audio/x-flac:*,http-get:*:audio/x-mpeg:*,http-get:*:audio/x-aac:*,http-get:*:audio/x-mp3:*,http-get:*:audio/x-mp4:*,http-get:*:audio/x-mpg:*,http-get:*:audio/x-wav:*,http-get:*:audio/3gpp:*,http-get:*:audio/aacp:*,http-get:*:audio/flac:*,http-get:*:audio/mpeg:*,http-get:*:audio/aac:*,http-get:*:audio/m4a:*,http-get:*:audio/mp3:*,http-get:*:audio/mp4:*,http-get:*:audio/wav:*,
02.12.2014 18:03:09; 7 Activate:True - Der Index war außerhalb des Arraybereichs.
02.12.2014 18:03:09; 8 MediaRendererDevice - http://192.168.100.111:49382
02.12.2014 18:03:09; 9 NewMediaRendererDevice:http://192.168.100.181:10184/ - Das Stammelement ist nicht vorhanden.
02.12.2014 18:03:09; 10 ControlListen - Das Stammelement ist nicht vorhanden.
02.12.2014 18:03:10; 11 MediaRendererDevice - http://192.168.100.111:49382
02.12.2014 18:03:10; 12 ProcessMessage - device 'uuid:D5DFED3D-02D0-2E59-8496-930B6A142FE0:',valid=False
02.12.2014 18:03:10; 13 MediaRendererDevice - http://192.168.100.111:49382
02.12.2014 18:03:10; 14 ProcessMessage - device 'uuid:77758F5D-AF4C-FB98-129D-8CE20E2F1DD3:',valid=False
02.12.2014 18:03:10; 15 MediaRendererDevice - http://192.168.100.111:49382
02.12.2014 18:03:10; 16 ProcessMessage - device 'uuid:1C7640F2-B54A-6A68-DCEF-D85F79FF6F17:',valid=False
02.12.2014 18:03:13; 17 RegisterDevice - Not Supported
02.12.2014 18:03:14; 18 RegisterDevice - Not Supported
02.12.2014 18:03:23; 19 RegisterDevice - Not Supported
02.12.2014 18:03:24; 20 RegisterDevice - Not Supported
Greetings, Michael
that looks like something already fixed last week. Could you re-download the plugin and also the latest version of musicbee itself from the 2.5 topic
MichaelP
o.k., I try - but the install (update) MB and Plugin I made yesterday from the 2.5 DL-Page.
I don´t use links from "Wishlist"...
Michael
MichaelP
 :D I´m wrong, after install mb_Upnp.dll has a newer timestamp (29.11.2014).
During I reply, I can hear MB-music from Yamaha  ;D ;D ;D
Thank yuou very much, Steven !!!
@hiccup, in the latest UPnP plugin version i put a bit of extra debug code in to see if the issue you are having is related to chunked streams. So if you do try it and see "chunked stream" text in the debug log then let me know
Thnx, I'll try it out, probably the coming week.
To be certain I use the correct version, is the link in reply #194 the most recent one?
