ATTENTION!
This skin has been updated for use with MusicBee 3.3 beta.
It is not compatible with version 2.5 or earlier.
Wave Bar feature is only available if using 3.1 version or later.
Background image is only selectable with 3.2 version or later.
I hadn't made a black-based dark skin, because I couldn't think of anything new that wasn't already in the dark skins currently available.
But I was playing some old jazz 78's and inspiration struck! Not something new, but something old re-done!
Bee78
Splash Screen
custom background image
"Unknown Artist" pic "No Artwork" pic
Stop Button is the RH "wing" of the Next Track button
Mute Button is the LH "wing" of the Repeat button
Updates
February 11, 2019:- MB3.3 update;
- minor fix to wave bar;
- minor change to some icons/images to reduce file size;
- introduced 3.2 errors fixed.
June 27, 2018:- MB3.2 Final update;
- minor fix to progress bar;
- minor change to some icons;
- 3.2 icons added.
August 25, 2017:- MB3.1 RC2 update;
- re-compiled with new SkinCreator tool.
August 09, 2017:- MB3.1 RC1 update;
- minor 3.1 elements added.
July 24, 2017:- MB 3.1 beta update;
- svg icons for high DPI screens used;
- re-arrangement of player bar;
- 3.1 wavebar added;
- icons updated.
December 16, 2016: - MusicBee 3.0 release version changes incorporated;
- minor tweaking of colours;
- arrows removed from all scrollbars;
- progress bar changed (some previous images were lost in HDD crash);
- some icons changed.
April 30, 2016: Included in Dark skins of MusicBee 3.0 download- MB 3.0 RC2 update;
- minor adjustment for "Delete" icon change.
April 20, 2016:- MB 3.0 RC1 update;
- larger included images optimized for reduced file size.
April 14, 2016:- MB 3.0 RC1 update;
- old player bar background restored;
- restored gradient to header bar;
- Progress Bar design changed.
February 1, 2016:- MB 3.0 upgrade;
- new Track Info area Art Deco elements to eliminate scaling artifacts in old curved ones;
- new Art Deco themed Progress Bar.
29 July, 2014:- MB 2.4 release version - incorporates simplified layout changes;
- added "CaptionBar.Command...Override" elements
- fixed use of "enlarge progress bar" cropping bottom of ratings and love icons
27 July, 2014:- MB 2.4 RC1 version - incorporates simplified layout changes;
- changed a few icons to more "retro" images
- "visualiser in tab" icon added
- changed panel forward/back icons for better visibility
- added missing gradient from Radio panel header
11 February, 2014: Included with MusicBee 2.3 download- 2.3 Release Update;
- alpha blending added for toolbar icons;
- new mini player layout colouring added;
- operating system dependent square corners added.
13 October, 2013:- moved Love and Ratings to under RH buttons;
- "Modern" compact player colours adjusted;
- skin styled "Unknown Artist" and "No Artwork" pics added.
4 May, 2013:- fixed highlight colour for disabled tracks (thanks Cliff);
- changed the look of the RH buttons to be similar to the Play buttons;
- Spectrum and Wavebar colours adjusted for skin.
2 November, 2012: - fixed "hide spectrum" problem (thanks Bee-side);
- fixed highlight colour problem in dropdown menus.
Downloadsavailable from MediaFire
hereAs this skin is included with the installation of MB, this link will only be active until Steven releases an official update.Source files
from Misc section of MusicBee Add-ons here
have
not been updated yet
Skin installation instructions and other information can be found on the
wikiI really like how this one turned out, hope you do as well.
