Author Topic: MusicBee Remote (Remote Control for Android)  (Read 502633 times)
kelsos
When I have some free time tomorrow. I'll take a screen shot and copy paste the log to make sure I'm describing the issue correctly.
Just describe me what exactly you need to do and we will find a solution.
Salmastryon
Sorry for the delay in replying.
My desktop in which MusicBee is running is 192.168.1.143, my cellphone is 192.168.1.149.  When I try to set the remote plugin to Range with the address 192.168.1.140 (149) and hit save the stats changes to stop.
I checked the debug log afterwards and got this. (this is the copy of the one I just did so I had exact info)
2017-02-22 12:36:27.9607 [INFO]
MusicBeePlugin.InfoWindow : 0
Connection verified: False
2017-02-22 12:36:27.9607 [DEBUG]
MusicBeePlugin.AndroidRemote.Networking.SocketServer : 0
Client 127.0.0.1 was force disconnected IP was not in the allowed addresses
If I put in the individual ip from for my phone(192.168.1.149 today) and 127.0.0.1 to the list and save it switches to running. So to make it work okay I just added each of the ip addresses in the range. So, I found a way for it to work, but I can't help thinking I should be able to put the range of available local ips in without being reduced to listing each one?
The firewall utility seems to be running fine I allow it to run with each save.
(edit: the reason I need the range is that my ip changes every time the router is power cycled which happens when we lose power.)
Last Edit: February 22, 2017, 05:52:49 PM by Salmastryon
Have you considered using a static ip on the cell?
Salmastryon
Unfortunately, I don't own the router and the person who does, doesn't want anything changed.
edit: I'm just glad I convinced them to change the default pass codes.
You wouldn't need to change anything on the router. You can set a static ip on the phone. Just make sure you use an ip address that's not in use. I may be wrong, but even if the router is set to only use DHCP, you should be able to set a static ip.
kelsos
Sorry for the inconvenience and thanks for the logs. It seems that I unintentionally broke something :/ I added a proper checker for the connectivity since it previously wasn't working correctly but I didn't check it with the filtering functionality.
I will fix it during the weekend and I will publish a new build.
Spiron
I'm getting an issue where if the wifi on my phone drops out and then comes back then the remote won't connect to MB again, it'll be stuck at "Authenticating".  I have to restart MB to solve this.
kelsos
Ok I am going to investigate.
Salmastryon sorry I couldn't get it ready during the weekend I hope to have it ready today.
kelsos
Salmastryon this should fix your issue. Tell me if this works properly and I will do a proper release/packaging with the fix.
http://www.mediafire.com/file/getv5m2d2kc7el3/mbrc_plugin_v1.1.0-loopback-filter-fix.zip
Salmastryon
Sorry for the delay in answering this. It still doesn't seem to work any differently from my end. Allow: All works, Allow:Range doesn't and Allow:Specific works only if I put 127.0.0.1 in as well.
Plugin Version 1.1.1.1459
The debug log below
2017-03-14 20:54:59.3482 [DEBUG]
sending-all: {"context":"ping","data":""}
Ping: 3/15/2017 12:54:59 AM
2017-03-14 20:54:59.7444 [DEBUG]
Stopping socket service
Socket starts listening on port: 3000
03/14/2017 20:54:59 : OnClientConnect Exception : Object reference not set to an instance of an object.
2017-03-14 20:55:01.2612 [INFO]
2017-03-14 20:55:01.2612 [DEBUG]
kelsos
OK that's weird I am almost certain that it worked properly when I tested it. Let me check again in the afternoon, I might have missed something.
sorry for the inconvenience.
Salmastryon
I hope the issue wasn't on my end. I renamed the old file to mb_remote.bak and copied the new mb_remote.dll into the folder.
kelsos
Don't worry probably I just missed something. Hopefully I will manage to check it today.
kelsos
Sorry for the delay.
It seems that I while switching from branch to branch I managed to create a build without the fix for some reason
I tested this to be sure and it seems to work properly
http://www.mediafire.com/file/5tmpdnen32pp161/mb_remote_loopback_proper.7z
