Thank you very much for the update
I'm glad there is a Developer to help with the plugin.
Including one of the services mentioned in my post above for Polish lyrics would be more than welcomed.
Both MusicBee and the plugin have failed so far in providing lyrics for many Polish songs. AFAIK there is no alternative software to use in that case. Implementing at least one of the 3 providers:
1.
http://www.tekstowo.pl/ - 671 061 lyrics in the database;
2.
http://www.teksciory.pl/ - 641 802 lyrics in the database;
3.
http://teksty.org/would make MusicBee more popular with Polish speaking users.
I'm eager to help with an API translation if needed.
Thanks for considering
BTW.
MusicBee has the highest rate in Music Organizers category in the most popular software portal in Poland (and one of top 20 most popular Polish websites):
http://www.dobreprogramy.pl/Katalogowanie-zasobow-multimedialnych,Kategoria,Windows,64.html To sort by rate rightclick 'Ocena' if you like to see MusicBee at the top
The number of downloads might be disappointing though:
only 8 198 until now, compared to 46 932 downloads for MediaMonkey Standard and even 24 515 for Helim Music Manager says nothing about the real value of the application. It only shows sad true that users usually download and use an application which is updated more frequently.
Being updated regularly (at least once a month) gives free marketing boost as the application is advertised on the main website. Users can review the app more often, share their opinions and download links.
Just a thought in connection with a discussion form yesterday about relatively small user base of Music Bee and some plugins.
