Author Topic: Lyrics Plugin  (Read 160526 times)
I've started off a plugin that can retrieve lyrics from web-sites that dont have an API. For now its just LyricsTime.com, Dark Lyrics, AZ Lyrics, lrc123.com (has synchronised lyrics), SongMeanings.net, Rap Genius, PLyrics.com (punk),  and UrbanLyrics.com
I dont have any plans to maintain this and hoping someone will pick this up and add other web-sites
http://www.mediafire.com/download/5t877tld29xt2b0/mb_LyricsPlugin.zip
Just unzip into the Plugins folder where MusicBee is installed (or create the folder if it doesnt exist). You can order the priority of the lyrics providers in the Tags(2) preferences screen
Last Edit: June 14, 2013, 10:11:38 PM by Steven
Euronymous
Would be awesome if this could fetch lyrics from Dark Lyrics or Metal-Archives.
Dark Lyrics has been added
http://www.mediafire.com/download.php?0dlkn8uhy4fafp5
you will need to enable in Tags(2)/ Lyric providers preferences
Last Edit: November 14, 2011, 09:23:13 AM by Steven
abhinavsays42
abhinavsays42
another great source of lyrics is songmeanings.net
it has a pretty exhaustive database of lyrics.
BeeFan
houston
Hey,
the source-code is down. could you reupload it? i would like to have a look.
I dont know if i can add new sites ... i nearly cant code ;)
oh yes, the configuring button in media monkey is not working.
br
houston
BeeFan
BeeFan
Really sad that no one takes time ...  :-[  :'(
tcman50
out of the box, musicbee found lyrics for 7500 of my 12000 songs, installed the plugin in this thread and found lyrics for another of my 1000 songs, so only 3500 more to go  ;D
hopefully there will be a few more lyric sites added in the future so I complete my collection  :)
i've added:
- lrc123.com (has synchronised lyrics)
- SongMeanings.net
if you already have this plugin installed you will need to tick these providers in the Plugins preferences screen
http://www.mediafire.com/?ywet721vf2c348z
BeeFan
Is this plugin already integrated into the version 1.4.4418 or do you you have to copy it every time into the plugin folder?
It would be nice if it could be integrated, the lyrics sites must not all be enabled by default.
