Author Topic: How to make MusicBee recognise your collection of lyrics  (Read 14660 times)
ma_t14
I read a couple if not more threads where people were asking whether there was a way for MusicBee to recognise a collection of lyrics they had collected before they started using MusicBee. It was not possible at the time but for those who are still interested, now it is possible!
When Steven developed this plugin I am sure he didn't have in mind for it be used this way  ;D
All you have to do is to download the MiniLyrics Helper Plugin which Steven developed for the purpose of Minilyrics and MusicBee working better together. Steven still has not provided it officially on the forum at the time of writting so here you get it from me:
www.mediafire.com/?i7jolioq9yr9lj0
All you have to do is to put the dll file to the Plugins directory inside MusicBee's own directory. If the plugins directory does not exist create it manually
Now from within MusicBee go to Edit>Preferences>Plugins (the last tab at bottom). There you will find the minilyrics helper. If it its not enabled, enable it. Now, the second check box reads "retrieve and show downloaded lyrics file - configured in minilyrics as:", check that and chose the second option which read "specific folder" and chose the folder where you have your lyrics stored.
Just remember that the filename of the lyric files should be the same as those of the original music files
Coxy939
Hi Guys!
Just wondering if anyone had a bit of an idea as to where i can get the newest version of the plugin? i tried it with the cnet version but for some reason it didnt want to work.
Check here: http://musicbee.wikia.com/wiki/Lyrics_Plugins#MiniLyrics_Helper_Plugin
MiniLyrics itself was having problems recently, but if you're just trying to use it as this guide describes, it should work fine.
